85general
should i do a 4" or 6" suspension lift? im gonna run 33's for now maybe 35s down the road, around here its mostly trails hill climbs an then everything else water, mud, ruts, i want the best all around lift
i fit 33x14's with only 3 inches lift and cut fenders.i could easily fit 35's with a true 6 inches of lift,the first and second gen trucks have similar sized wheel openings.it makes me want to laugh when i see 9" lifted roll over specials running 33's just because they're scared of a little trimming.i had 31's on my truck no problem with no lift an no cutting ? then i cut my fenders an could fit 33's no problem. with a 6" an my already cut fenders i could fit 35's easy with alot of room left. so it seems anyways maybe not though.
evan what are you talkin about problems with a 6" all suspension? that was an option to was to the a 4 an then body lift. but i was thinking just do suspension i dont like body lifts but i wanna keep my truck as stable as possible everything around here is off camber type stuff.
you wont get 35's on your truck with 6" of lift unless you almost completely cut the fenders out.
It is VERY tight on a '93+ Ranger with only 6" of lift and 35's. Maurice (mjones) was running 9" of lift on his '97 to clear 35's and be able to flex without rubbing.
