rcpbob
I have a 2020 Ranger XL Super Cab STX w/locking diff. I just been playing with the four wheel drive, and some things I don't understand. In 4 High, with shifter in D, the car shifts and drives like in 2 High. But when in 4 Low, shifter in D, the transmission shift points change to about 3,000 rpm, and if left in Drive, will only go up to 5th gear. No matter what rpm you run up to, top gear stays at 5th. If you put the shifter in S, you can manually shift up to 10th gear with the toggle switch on the left side of shifter handle. Is this how it's suppose to act ? I've had older Ranger's (5 spd. auto) and other 4 wheel drive trucks, and in 4 Low they all would shift up to the highest gear while in Drive. Thanks for your comments. Ride On !
