Fast Doc
- Feb 22, 2009
- Automatic
4 Low not engaging. Please help. Replaced sensor no joy
I DID use the search function, but could not find what I needed. Almost but not quite.
I have a 4.0 V6 1992 automatic STX. The pushbutton for 4WD works fine, and I know the 4WD works, but it will not enter 4 Low. Not even in Park or Neutral with the brake on. The starter overide switch works, it will not start in gear, and the brake light switch works also.
Today I will crawl under and check the resistance of the blue and green wires from the low speed sensor and look for 250-450 ohms but my questions are:
What is that switch called and/or the part number so I can order the right thing?
Is it hard to replace, or just a quick job?
If the switch checks out, what else could it be and what would be my next step?
Thanks in advance, gents!
Bill.
Bill.
