- Jan 29, 2010
- Ellsworth AFB
- Automatic
Just picked up my set of tons, gonna be cutting down my rear wheel base and trying my hand at a tri-4 in the rear with air shox. For the front I was thinking 4L, but after seeing yours and realizing there is little room the 3 link looks like it would work just fine.
Ill be using a fuel cell to get rid of that low-hanging OE fuel tank.
Any words of wisdom or suggestions prior to the build? It will be a d60 and 14B 4.56 locked disc all the way around.
4.56 isn't low enough unless you have some sort of large V8 (351/BBF) I would be looking 5.13 and deeper.
Plate your frame
Wont be as bad since he is ditching the leaf springs in the back. Less frame twist with his setup. He will need to box and plate the mount sections outside of that I doubt it will have many issues.
