4" lift brake line question
yewwoodtree
Nanaimo
Hey so im throwing a 4" lift on my 1990 ranger 4x4 and was wondering if the stock brake lines are going to be fine or if longer ones are required, Thanks!
i would go with some extended ones, it will be cutting it close with the stock, esp if the suspension has a little flex to it
you will need extended lines for sure
so what kind of lines do you guys run? rubber or braided stainless? I went to lordco and they said that the only after market extended lines they could get were skyjacker ones for 120 bucks
go to the tech library like railman said, get the part numbers and take them to autozone, they'll get what you need and if they dont have it in the store they can order it for you, usually next day for free
