guitarsgethegals
i noticed that the rough country does not make there lift for 2004 trucks could you still bolt this kit on or would it not work? if not i was thinking of doing the lift part by part what would the process be for this?
jump??
The entire suspension system changed in 1998, not even close
The 5in lift you posted wouldn't be bad, but I definatley would jump it
As in, you go fast and hit a jump, and the tires leave the ground. Then you hit the ground and your new spindles shear off
