4 cyl to 6 cyl bellhousing interchange?
turbo2.9
Mnt calvary, wi
I have an 87 2.9 2wd 5 speed transmission. Its whining really bad so im looking for a cheap replacement. Do the 4 cylinder and v6 transmissions interchange? I can get a 4 cylinder 5 speed 2wd for really cheap so i was wondering if i could put the bell housing from my truck onto that transmission. The 4 cylinder truck is a 86.
Thanks in advance. Wayne
85-87 Bellhousings are freely interchangeable on the transmissions so if you already have the correct bell it'll bolt right on.
The '85-87's are most easily identifiable by their "Top connect" slave cylinder
it's about 11 O'Clock viewed from the rear
IF the slave port sticks out the side, at 9 O'clock you a 1988-up transmission and you have a problem
Alright whell it turns out that the junkyard that i called has a 2.9 transmission that i need so im alright.
i think it should be mentioned in the tech liblary that the 4 cylinder transmission fit the 6 cylinders with a bellhousing swap though.
thanks a lot, wayne.
