4.88's in at 03' ranger
mud junky
NH
I want to put deep gears in my 2003 ranger, but wonder if I put in 4.88's if the front pinion gear would be to small and cause issues. Any thoughts on this?:dunno:
4.88's have been used for a long time, I can't see the issue. My theory if you are breaking pinions you need a bigger axle.
The '98+ low-pinion setup isn't the best frontend, but it should be fine as long as you don't romp on it.
I will be romping on it, but only with 33" tires.
I've seen quite a few Jeep LP dana 30's break pinion gears, I believe you have the same gears?
The one's I've seen all have had chromoly shafts, and one guy in particular that used to break a few gears each year had a front locker.
I would say you're probably alright, but pushing it. Different tires would make a difference, as well as what terrain you are driving in. 33 IROK's on dry rocks are a whole different animal compared to, say, 33' AT's in mud.
I'd take a pass for a better axle myself (HP D44 SAS).
D35 gears are a little bigger than D30 gears, but the bigger issue here is them being lo-pinion. Driving them on the 'coast' side you lose about 30-40% of their strength, a lot of it due to gear deflection from the angle on the teeth.
Why Ford went to LP gears when they redid the frontend in '98 (or '95 for Explorers) is beyond me. :icon_confused:
Like you said, they are weaker when you drive them on the 'coast' side. However, if you are in reverse they you are using the gear's strong side.
I would guess that in the normal use Ford designed the truck for that more stress is going to be on the front in reverse, like getting stuck and trying to back out of a snow bank going uphill?
That idea might hold a little merit on a short-wheelbase rig like a Jeep TJ where weight transfer to the front can potentially be greater while backing up something, but on a longer pickup truck it makes far less sense.
If the axle was too weak originally (very doubtful when everyone running 35" and even 37" tires on the earlier HP D35 aren't experiencing gear failure), maybe a bigger pumpkin would've been in order.
I am just trying to make my Ranger nasty fast. Front end is "open" and all I do is mud drag racing.
