4:56 jeep gears
liftedredranger
york pa
ok i have a set of 4:56 gear for a dana 30 jeep rear will it work with the ttb dana 35???
Did you mean Dana35 Jeep rear?
In any case, no, those gears will not fit the TTB D35. TTB axle gears are hi-pinion, rear gears are lo-pinion.
no i mean that jeep dana 30 out of a cherokee or wrangler will thos gears work with the ttb 35 carrier
No they won't.
TTB are high pinion. Dana 35. Reverse cut. Rear gears from a low pinion, Dana 30, standard cut will not work.
Jeeps do not have a Dana30 in the rear.
And D30 front gears will not fit either, regardless of HP or LP.
no jeep cherokees have a dana 30 in the front and its a high pinion rear the the ring gear is a ten bolt so thats why i was asking if theyll work for the ttb
Here, let me clear this up for you.
1. Jeeps NEVER had a Dana 30 in the rear.
2. Jeeps HAD a Dana 30 in the front.
3. Each axle has its own gear set. I don't believe there are any axles that share gears.
And the rear is not high-pinion. Only the fronts were.
omg yes thats what i was trying to said the dana 30 jeep REAR as in the AXLE REAR not the jeeps rear axle
Next time, please clarify which end of the vehicle the axle was going into. If you keep saying rear axle, then 99.9% of the time people will assume a REAR as in back axle.
I think he is calling any differential a 'rear end'
yes i am calling the rear end a rear im sorry about the ????? i just needed to know if anyone has try to do this or no
They will not fit, All gear sets are specific to the axle they were made for (d30, d35, d44, d60 etc.).
I'm still confused????? no not the rear, but the rear of the rear that's not in the rear. you know.... the rear.
Duh! I must be stoopid or not very SMRT
