rocks
I have Skyjacker drop brackets they came on the truck when i bought it. They are 4-6" ones. I put the brackets in the 4" holes with 6" Skyjacker XJ Coils I ended up with something like 7" of lift. My truck is a Single Cab Short bed 4.0 manual everything. The 6" skyjacker springs would not compress at all.
I do not have the money for custom steering yet, so I was aiming for 4" suspension lift with 3" bodylift. Trying to keep the steering level for better alignment. I also have the Extreme Drop pitman arm. Superlift Extended radius arms and superlift rear springs I pulled off a rolled truck.
I decided to order some Rubicon Express 4.5" lift springs for an XJ. These springs are perfect for a lighter truck. The do compress and give 4" of lift. These springs are right around 21" long with less coils than the skyjackers.
In the 4" holes my steering is very close to level by eye balling it. I may need to space my coil buckets out about an inch or so to help with spring bow. And now I need to redo my shock brackets after making them for the 6" springs. I was able to drive it around tonight in some alleys. The front end lifts up when I put it to the floor but it comes right back down with the Dual 5150 Bilstien shocks. Has quite a bit of front body roll.
Now I need a softer rear spring. I may take some springs out of the superlift pack or use some chevys. But the front is nice and flexy. Ignore the lugnuts on the steering I cant find the castle nuts and a chevy lug nut is the same thread pattern lol.
Shocks
Skyjacker Coils
With Rubicon Express 4.5" XJ springs.
Steering
Height with fender on
Leaky brake lines
Need to fix this. Do I reflare it or get another one of those blocks? I dropped the Caliper a few times. So I am sure I screwed something up.
Shocks
Skyjacker Coils
Steering
Leaky brake lines
