I'm wanting to add this amp I have to ALL 4 of my speakers in my truck. I would like to wire them the best possible way with what I have. I'd appreciate and help from audio geniuses. Please.....
I have 2 of these:
Pioneer 6" x 9" Three-way Speakers, TS-A6973R
* Shallow-mount basket design
* Woofer: carbon graphite IMPP interlaced with Aramid/basalt fiber
* Surround: rubber-coated cloth
* Voice coil bobbin: Glass-Imide
* Copper voice coil wire
* 5/8" PET film-dome tweeter
* 1" soft-dome midrange driver
* 92 db sensitivity
* 4-ohm rating
* 31Hz to 29kHz frequency response
and 2 of these:
Pioneer 6" x 8" 3-way Speakers
Technical Information
# Output Power50W (RMS) / 240W (PMPO)
# Driver Type1.62" Neodymium Neodymium Midrange
# 0.37" Tweeter
# Frequency Response30Hz to 28kHz
# Impedance4 Ohm
Physical Characteristics
# Dimensions6" Height x 8" Width x 2.5" Depth - Mounting Depth
This amp:
Dual XPA2500 300 Watt Amplifier
* 50 Watts RMS x 2 channels @ 4 ohms
* Signal to noise ratio 72dBA
* Variable high pass corssover and variable low pass crossover
* Selectable crossover high pass low pass full range
* Variable bass boost
My head unit is a Pioneer also, it's older, but new enough for the Ipod adapter. I bought it back in 06', and was the highest grade at wally world.
Btw, it's mostly rock/classic rock based music I crank. I'd appreciate any advice.....Thanks!
Ryan
I have 2 of these:
* 92 db sensitivity
* 4-ohm rating
and 2 of these:
# 0.37" Tweeter
# Impedance4 Ohm
This amp:
Ryan
