aaronhahn777
I have play in the rear differential carrier (8.8 4.10)? It is the small gear inline with the main cross pin and has about a millimeter of play.
Can you rebuild the carrier? Or should I just purchase a used one?
(so much for my brake job... hahha. started with that... then found a bearing leak... then I pulled the shafts to replace the seals. Then I found the loose gear... now that explains my highspeed vibration... sheesh
At least automotive work is fun.
search words: 4.10 differential bearing seal 8.8 ranger 4.0L XLT
