4:1 kit for 1350?
DOZER
mother lode
just wondering, does any one make a 4:1 kit for the bw 1350, if not 4:1, then any other low range ratio options?
There are no gearing options for the 1350/1354 series transfer cases found in rangers.
The only option is going to a doubler set up or getting an atlas transfer case.
If you have seen the inside of the 135X series cases you would understand, they are not gear driven cases (by changing gear sizes, you change gear ratio), they have a drum type setup with rollers around a center gear, when locked, it gives you one ratio, when unlocked, it rolls around the center gear giving you the second ratio...hope this helps
SVT
