4.0L sohc engine swap
bvmwalker
I just purchased a 01 ranger with a bad 4.0L(timing chain went) and I have access to a 4L sohc from a 98 explorer, does anyone know if it will swap into my ranger
Yes, just use your ranger Intake. Also while you have the engine out, change the tensioners to the new updated ones, and youll thank yourself.
Absolutely change the tensioners before installing that engine. They WILL fail, unless they've already been replaced with the updated parts.
