plainsranger
Guest
When you put in the electric fan, did you use the fan shroud?
i just started having my truck overheat. it doesnt sky rocket it just slowly starts going higher and higher while i am driving on the highway... when i let it sit there and idle it starts to slowly come down which doesnt make any sense at all. I checked to make sure the water pump is circulating water which it is and the thermostat is also opening and my radiator is clear. i pulled the spark plugs to check the compression and i have good compression the only weird thing is the are white and showing i am running lean.... i hae been also getting real bad gas mileage and it also smells like it is running rich which really confuses me...any ideas what could be going on??? thanks in advance![]()
