shadow88
Well tomorrow I'm going to pick up the donor, and some new parts, and then the 4.0 swap begins, wish me luck!
Heres a question, my donor is a automatic, my b2 is a stick, I do have a harness from a donor with a stick, should I use the stick harness? Would this eliminate some trouble?
Both donors are 91
I think you will need a computer for a manual because of the neutral safety switch
I'm currently runnin an auto ecm . I have a 5 spd. It can be done.Use the harness from your donor, splice in your headlights and tailights. That should cover it.
Splice the headlights? I thought the headlights setup were the same on the bronco as the explorer?
The tail lights should no be part of the engine manage harness.
At least it was that way with my 87, I don't remember removing anything for the tail lights in the 93 explorer harness.
Sent from my myTouch_4G_Slide using Tapatalk 2
