Flingarrows
- Aug 18, 2008
- Automatic
I have a 99 Ranger 2wd 4.0 automatic with 100k on the odometer. I had constant codes for lean, misfire, etc. I clear that with a new set of heads last fall, as well as upper and lower intake gaskets, tpfe and hoses (tpfe cracked), Coil, plugs wires. Incidentally, the old coil was not bad, so I have a spare. The burning oil smell was gone, idled smooth, no codes.
Fast forward to the last few month. Wife tells me that truck stalled, and wont go. Kind of ambiguous, but it is happening more often and I finally experienced it. So this is an intermittent thing. when it runs good, it runs good...
Symptom#1 pull up to a stop, idle drops very low, and stalls. feathering pedal keeps it running. I have has 2 incidents now, where is dies and starts hard and wont rev up, then goes away after a little while.
Symptom#2 and cruising speed, it intermittently feels like a cylinder is not firing. This goes in pulses of maybe 5 seconds of rough, then smooth for 5. This cycles like this for the whole drive. Other times it runs fine.
No CEL, but bought a code reader and had a code relating to TPS and MAF not syncing.
It had the dying thing today, and I drove it hard to keep it going, and then it went away. No stored codes...
Took it for a drive after work, and only had the missing thing at highway speed. Again, no stored codes.
Here is what is new in the last 3-4 weeks:
MAF, TPS, IAC, Battery (interior light left on, was time for a new one anyway).
Any ideas?
Any ideas?
