4.0 waterpump bolt dimensions 93 ranger
steelieseeker
Webster Florida
Bought a 93 ranger at a grate price all it needed was a waterpump and bolts for the waterpump and the pully.I have been searching for about 6 weeks with no luck. I may be able to get something to match if I get the actual dimensions but no luck on that either. Any information on these bolts or leads what will cross fit would be greatly appreciated.I have checked out the local boneyard and can only find 98 and newer models. Thanks
Go to parts store and get one out... can't remember if they are metric or not. But gets a 1/4 5/16. M6 M8 and see.
I might have a spare water pump pulley. I remember replacing mine for some reason.
The bolts I remember resembling my dirt bike bolts, so its definitely metric. I am not sure if theyre all the same length.
Might be able to have little bob pull them off of one of the engines at the house.
I can get the pully but I can't get the bolts to put it back on the waterpump
Oh so you need the pulley to pump bolts, not the waterpump housing bolts?
I think they also hold the fan on too. 4 bolts, shorties...Definitely Metric. I might be able to dig one up and measure it. A good hardware store will have them.
I need both water pump bolts and pully bolts
water pump housing to timing cover bolts are m6x1 but I'm unsure on the length. they're all the same if memory serves me correctly
going home tomorrow.....you got this solved?
