4.0 vin code????
96Greenster
Rio Grande City
Sup guyz, well the previous owner had the engine swaped from a newer ranger, but didnt tell me what year and I forgot to ask. So, what im trying to find out is where would the Engine Vin Code X or E be found on these engines?? I gave it a quick glance when i changed the oil but didnt see anything. Please help me out...:icon_thumby: THNX:icon_cheers:
I'm far from knowledgeable but....
X — 4.0L EFI-OHV, six cylinder (pushrod)
E — 4.0L EFI-SOHC, six cylinder (overhead cam)
So, if it's a pushrod/overhead valve engine and you have a '99 Ranger and a "newer" engine was put in it could only be a '00 since they stopped making them in '00.
Here's some info on how to ID a OHV 4.0:
http://www.enginebuildermag.com/Article/2356/rebuilding_the_ford_40l_pushrod_v6.aspx
I have a '99 w/4.0 that I bought used and just went through verifying what vintage 4.0 it had before I went to order parts. Turns out it appears to be the original '99 engine.
Hope this helps. (And I hope I got things right)
Ron
BTW, I don't think you'll find a vin code X or E on the engine.
The code is useless to you, because the only "code" you have is for the engine that's gone.
It is VERy unlikely that someone retrofitted a 4.0SOHC
But the EASY way to tell? are the valve covers painted steel or cast aluminum?
On the OHV engine they are steel
On the SOHC engine they are Aluminum
AD
Well its a OHV...:bawling:
I knew it didnt feel like 200+ hp...:icon_rofl:
Owell, still strong enough...:yahoo:
Thanx guyz!!
