Got this 85 with a 4.0 OHV swapped in and started tearing it apart having to fix the alternator wiring and some other stuff. Well it will run fine for about 10 minutes till it gets warm (I think) then it loads up and chokes itself unless you give it throttle. Now I went to the JY today to look at motors cuz mine has what I think is a cam sensor in the back wher the dizzy should be but the wiring harness didn't have a plug. Well the behind the motor harness was behind the radiator and I found a plug that didn't fit anything. Figured out that was for a MAP sensor? Looks like one anyways. Plugged that in and runs crappy almost always. And I can't plug the IACV in or it will idle at 2k rpm. from what I gather is the motor and wiring are not from the same vehicle. The motor is at least a 93 and the wiring is prior to that. And no I haven't checked the ECU.
My question is: Should the motor run without the cam sensor if the wiring and ECU don't need it? Basically can you run an older harness on the newer motor? Any suggestions are very appreciated and really needed.
Thanks
Thanks
