aaaaaa
- Jun 17, 2009
Hi,
I have a 2002 Mazda B4000 4wd w/ the Ford SOHC 4.0 V6. The engine runs smooth, but I've noticed a dull, metallic tapping noise when the RPMs climb around 2700 and above. It is coming from the engine compartment and sounds like valves out of adjustment.
So - can the valves be adjusted on the 4.0? If not, what might be causing the noise I'm hearing?
