DemonRanger
- Aug 22, 2016
- Automatic
Hi all, looking to change the motor in my 03 4.0 sohc ranger. It is 5 speed standard, 4x4. It developed a rattle coming from the rear passenger side of the engine.It rattles upon start up, then rattles half consistently while driving. I replaced both timing chain tensioners a while back and no luck.
This is the second motor already in the truck. My truck has about 360,000 kms on the body and this motor has about 200,000 on it.
My plan is to pull this current motor and replace it with a less mileage newer one. Also the motor thats currently in my truck I am going to rebuild it over time myself as a project to learn engine work
What motors will fit in my truck? 2003 4.0 sohc, 5 speed. 4x4.
Do i need the computer with the motor or just the motor? I am a bit dumb when it comes to engines as i have never had to replace one before.
Also is there anything else I need? Are certain years better ?
I have also found a few engines, some are still in trucks that are not running. Is there a way to get the motor running for a test before I buy one? The sellers say the engines are good with xxx miles however i'd like to hear it running of course before i buy anything. I need a new motor dropped in as soon as I can. The old engine is going to be my project to tinker with over time.
Thank you for any advice.
