4.0 Ranger hi-rev problem
hillvalleybronc
Im working on a 4.0 ranger. Put new head gaskets on it. new intake gaskets. Put everything back together, but it revs up to about 2500 and stays there and doesnt go down. I have checked for leaks with carb cleaner and cannot find any. The computer isnt tripping any codes and i am scratching my head now.. any help would be appreciated. thanks
Is the throttle closeing all the way? Are ALL the lectric plugs plugged in properly? Is there a vac port open? Or a vac hose not installed? If all these are correct then go after the vac leak again... This really sounds like pilot error.
Big JIm
If it was the IAC wont the idle be intermitent... Like hi, low, hi, low etc..??
