4.0 rad
just truckn
suburbs of philadelphia
2.9 V6
6inch suspension 3inch body
Hey guys I have a 90 rang with the 2.9 I want to know if anyone has replaced their rad with a 4.0 rad I know they r the same size and that the 4.0 is a 2 core I think I saw some time ago someone who did this but had problems with the upper hose so can anyone tell me if they did the swap and what hose they used any info is appt
The 4.0 manual transmission radiator is a single core but the automatic is a 2 core. I just replaced my radiator in my 4.0 manual with a 2 core from an automatic and it runs much much cooler. When I swapped to the 2 core, just leave the plugs in for the automatic transmission cooler, and you'll need both upper and lower hoses for automatic. Also a new fan shroud will be in order, I'm still running the fan shroud from the single core but I have about 1/8 inch of clearance between the shroud and the ac clutch, it even hits when the engine moves on acceleration but nothing major. Also the mounting clips on the bottom of the shroud are different between the two, wider on the 2 core.
Oh I forgot I have an automatic transmission. But Mike u have a 4.0 already i have the 2.9
Someone else will have to chime in on whether or not it will actually fit. I'mpretty sure the water becks are completely different between the two, do you have air conditioning?
The 4.0 automatic radiator upper hose connection points out towards the fender so you'll have to get crafty, maybe you can try a universal rad hose, like you see on hot rods and older custom cars
Oh so it points out I guess I might just have to go to anew auto parts store and look them up
But as for it fitting it should they r both the same size except for one is a 2 row I'm just wanting to know about the upper hose
A set of 2.9 auto trans hoses fit just fine, ran them for years back in my 2.9 days, no universal hoses necessary
Sent from my SM-G900P using Tapatalk
Not always. I have a single core, auto trans, 4.0 rad. The trans cooler sticks out farther than the rest.
It's a rare one to see though because all 4.0s with AC got the dual core rad, and AC and auto trans are options that were common to see together.
