Does anyone have a diagram / picture of the oil flow path for a 4.0 OHV? I am trying to figure out if I may have a passage blocked or if it is the oil pump.
(99 Ranger 4x4, 139,xxx miles).
I seem to not be getting oil to the camshaft position sensor. I replaced it once and now am getting that squealing noise again. I am pulling the intake this time to change it. When I pulled the valve covers they appeared dry inside (not much oil that I am used to when pulling valve covers on other engines). Also the lifter valley appears to be quite dry. The pressure gauge in the dash shows good pressure so I am thinking it isn't the pump. Not getting any lifter noise either, runs very smooth.
I have put in SeaFoam a couple of times also. I really don't want to pull the engine if I don't have to.
Any ideas are appreciated.
