Glen James
If I have a 91. 4.0 engine with no wiring harness can I take the harness from a 91 explore and put the engine and wiring harness in my 88 B2
Why swap?
4.0 has more torque out of the box, sure.
2.9 has more overall potential than the 4.0.
Mr. James,
You will need the complete wire harness with all sensors, the computer and to simplify it, the dash from same donor vehicle.
This forum has perhaps the most comprehensive threads regarding putting a Ford 4.0L OHV into a 1st gen Ranger/BII. I am doing the same thing right now in an 87 BII with a 94 non- EGR 4.0L OHV.
So go to the engine swap folder and look it over a bit; it will probably answer a bunch of questions and give you some new ones . )
You don't own a Ranger.He's probably tired of the 2.9 eating coolant and leaking oil. It's fairly common knowledge - a 2.9 can go farther on a gallon of gas than it can go on a quart of oil. Not to mention that the 2.9 can't even get out of it's own way.
