tobyduck
- May 5, 2010
- Automatic
98' ford ranger xlt, supercab, 4.0 V6, 2WD, Automatic
When cranking cold it will crank, sputters til it gets around 500 rpm. It acts like it is trying to idle up and if you give it gas it just sputters more and goes around 300 rpm. (I myself am amazed that it will run at that low rpm) This lasts around 15-20 seconds and then it will idle up to about 1000-1200 rpm. I cant fully drive it or give it gas for like a minute, after that its fine and runs great when it's warm...I don't have a clue what's wrong and there is no code. There is no problem with the MAF sensor or fuel pressure or fuel filter, fuel pump, spark plugs, coil pack, etc. I have been told that it is a water temp sensor problem but I don't know how to resolve it,
God Bless
God Bless
