sward1979
- Feb 7, 2009
- Automatic
I have done everything I know of. I have replaced the coil, wires, plugs etc. I have done that more than once. I done a compression check and found that one head was cracked so I replaced both. That brought the compression up. I have had the injectors checked and replaced the fuel filter. I have replaced the computer, ignition module, crankshaft sensor. I took it to the transmission shop thought it might be there but they said everything is fine there. It never trips the check engine light so I can't even get a code. Any help would be great.
