4.0... 3.8?
ignerntkneece
whats the difference between like the 3.8 v6 in the super coupe and a stock 4.0 ? its not the sohc 4.0 either... the older 4.0 like in my 94 ranger??? i'm wonderin if the charger would bolt up???
Nothing is swappable between the two.
Hardly anything is swappable with engines in it's same family...
Best best would be to get a charger made for a 4.0L. I haven't heard many good things about the stock S/Cs on the 3.8L, but I've never owned one either.
Pete
i think the 3.8 was a 90 degree motor, possibly a 302 bore and stroke wise. (like the g.m. 4.3 is a 350 v8 les the back 2 cylinders) ive not seen them though, only heard about them.
________
Javelin
aight i was jw wonderin... i found a super coupe i could get pretty cheap cause its got a blown head gasket but thats all i wanted was the charger... anyways...
what about the bellhousin, would my transmission bolt up to a 3.8? i could change the whole motor?
3.8 shares same bellhousing bolt pattern as 302.. and 351w & 351C?
I've got both a 3.8 and a 4.2....They are in the same family...90* With a 302 bolt pattern.
Nothing in common with a Cologne v6.
The 3.8 has slowly developed a taste for antifreeze. That vehicle was replaced with a 07 taurus that is getting about 25mpg...whereas the Windstar was lucky to get 17-18. Oh...and I KNOW the 3.0 will hold up!:icon_thumby:
