3rd brake light leaks water
dhdaniel
Baytown Texas- Gulf Coast
2.3 EcoBoost
Looking for any suggestions, Water is leaking in, headliner is soaked right there in the middle where the light mounts
appreciate any help
thanks
Dave
Pull the seal off of it.
Put a big bead of rtv around the light.
Put a thin coat of oil around the hole in the cab.
Put the light back in overnight.
Pull the light back off with it's new seal attached.
Clean the oil off.
Then reassemble.
Sent from my HTCONE using Tapatalk
I just used black caulk and caulked around the light on my 99 and that solved the problem.. 5 minute fix
