3l cab swap
dasranco
can i put a 3l cab on a 2.9l frame and engine and plug the harness in or do i have to change the dash harness ??????
Frames and cabs are not related to engine size in any way....going to have to explain exactly what you are trying to put on what....
if i put my 3.0 L cab on 2.9 L frame do i have to change cab harrness or will it plug in and work
Ok, lets take this from the top. There is no such thing as a 3.0L cab or 2.9L frame. The frame and cab are associated with the year of the truck, not the engine.
The dash harnesses are essentially all the same for rangers in any give year, Either Tach or non tach.
the engine bay harness is "all one piece" and it needs to go with the engine.
AD
i have a 91 3.0l ranger supper cab and i want to put it on a 2.9l bronco frame i know cab mounts are different and i have to put wheel wells in the cab for back tires when i plug the 2.9 edgine harness to the cab is it going to work or will i have to put the bronco harness in the ranger
