Grunizzle
01/2013 OTOTM Winner
U.S. Military - Active
OTOTM Winner
Solid Axle Swap
Damn I have a BL too, guess I cant wheel anymore because I only pose now...
and statements like this is why u and i butt heads from time to time.....i have built several rangers, most with body lifts, inorder to create clearance for a small block, 4spd etc, and i garuntee u my "POSER" trucks would go further off the beaten trail then yours will.
that being said, with the t-bar cranked some blocks in the back and a body lift u should fit the 35's but rubbage will be a issue
hmmm $160 dollar lift to clear some new tires and make it easier to work on stuff, or $1600 for a sus. lift.... which one seems the most logical...
logical would be to save some money for about a year or however long it takes you and buy what you will want in the end. it just causes more of a hassel to put something on that you know you will want to remove later.
like i stated before, its my opinion. i did put a body lift on my old ranger and that son of a gun was top heavy as hell. i hated it from the moment i drove it with the body lift and it looked ugly as hell.
tire clearance... id rather get glass fenders for better tire clearance. pre runners have up to 39" tires and most sit lower or the same height as a stock ranger granted they have an extreme amount of fab work done. but most guys who dont want to spend the money just go up to 33s or 35s which will have no problems with a 3" rise and 3" wide fiberglass fender. you could even go with 6" and 6". you also spend 1 hour tops on fender and its easy to put the factory ones back on if you want.
from my experience in socal, body lift=poser. theres even tapered bodylift for the "prerunner" look.
keep the factory ride and go glass. dont crank or BL. well keep the cranking to a minimum.
why would it be logical to save money for a year to put a suspension lift on a IFS ranger that will give u NO advantages over the stock design, why would it be logical for someone not to be able to go wheelin for a year until they can afford a overpriced suspension lift that offers no benefits.... if u save money for anything on a IFS truck, it would be for a SAS, and the reasoning for the body lift in the mean time even if u take it off at a later time is so during the year it takes some people to save up the money for a SAS they can have fun with there truck how they see fit, by bein able to run a larger tire, have better ground clearance etc......
also, as far as glass fenders go, how much does a complete glass kit cost, along with the time and effort and cost to make them work properly, when u can for usually under 200 have the same amount of room for larger tires
what bout goin to a junk yard and gettin a set of fenders to cut out and repaint? what do yall think bout that idea.
