So a friend listened to the ranger run for a lil bit he doesn't hear any death noises, we are getting oil following to the filter so we now believe it might have sucked up some crud and clogged up the oil passageway from in between the pump and oil pressure sensor. I guess ill try some air blowing up through with the sensor out. And see if I get some junk to blow out it might have even sucked in the gasket between the block and oil pump.
