MorePower7701
I have a 1990 Ranger, the A/C system is fairly new, all the componates appear to be working correctly, except for a leaking low pressure line. I bought a can of 134a + oil charge to recharge the system, it came with a cheesy presure gauge that states that 35psi is fully charged. I charged the system to 35psi, the suction line is almost sweating and the vent temp is about 52deg with a 91deg outside temp.
I do home HVAC residental and commercial work for a living, it seems that the system is not fully charged, close, but not fully charged. The temp inside the cab was 100+deg so the air going across the evap coil was hot. Would the hot air going across the evap coil cause a the higher suction pressure?
Thanks
Thanks
