33x14.40????
07rangerfx4
ga
will i have any problems in the drive terrain running this size tire?????
The severe girth of the tire may cause rubbing issues, depending of course on your wheel backspacing. Those suckers are wide.
It looks like you already have 33"s?
Those are going to be heavy to turn, I wouldn't be surprised if you found you want taller gears and like was mentioned you 'll probably get some rub on turns but I reckon they should fit allright...
im not trying to be an ass but i keep seeing this around here. the number for gears is numerically higher but the gearing is lower. he would need lower gears not taller. but he needs some wider rims with some different back spacing
i plan on liftin the front 2-3 more inches to help not rub...i have no problem turning the tires i have now..i dont really offroad so i THOUGHT id be ok...
Yes, you're dead right, he might want lower gearing which is numerically higher...
^^^ thanks man glad you could agree and not get mad i just keep seeing people saying it backwords on here and its driving me nuts
