31x10.5r15 Tire Pressures
Dark_StRanger
I was just wondering what people think i should set my tire pressure to on my 91 ranger 2wd im getting a lot of rear wheel hop. All the suspension is new back there so it shouldnt be that. I think it might be the pressures im going by the factory set pressures which is 32 if i had the stock 205/65r14
thanks
Pickup trucks are light in the rear, some hopping will always be normal. Better quality shocks might help with it somewhat, although I wouldn't lower the tire pressure below 30 PSI.
I'd run it how you have your best contact pattern for wear. I run my 36" tires at 22 psi. My explorer 32's I ran at 30. Any higher and it was like riding on bricks.
i took side walk chalk and scribed a heavy line across my treads on all corners. then drove around the block and checked and adjusted pressure till i had the best contact. i am running 31 10.5 also. and 28 psi is the best for my truck.
