302 starting
That noise is the impeller hitting the stator; when the torque converter is on the tranny, the input shaft and stator shaft keep the parts from hitting each other. So if the converter was working before it was removed it should be OK
unless, it was left outside and got water in it. Parts can rust inside the torque converter.
p.s. my 68 mustang with 289 has a smaller torque converter from a 6-cylinder transmission. Had to modify the flex plate to make it work, but it will have a higher stall speed on a larger motor. Helped prevent stalling the engine with a race cam.
the converter never worked for me. The second i put the truck into gear it would stall out everytime.
If i were to put in a shift kit rather than the manual valve body, would i need a kickdown cable to make it shift?
you only need a kickdown cable to make it 'kickdown' into 2nd for passing a car... dont know what to tell you with the info...but thats definatley NOT an AOD. its a c4 or c5.
the guy i bought it from said it was a C4 so im going to take his word. Seemed as if he knew what he was doing.
That's a C-5 bellhousing. Look at the casting numbers, that'll tell you for sure. It would have a 79 or so or later casting number. As such, a C-4 torque converter will not work with it, the C-5 bell is deeper than a C-4 bell.
i used the converter that is matching to the bell. All out of a foxbody. I dont know if the C5 was stock equipment on foxbodys but the guy coulda swapped in the trans, who knows. The bell IS thicker than the other bell which was a C4. Now we know this is a C5 bell and C5 converter. This is really confusing now. Im thinking that C5 converters DONT work on C4 trans's due to the lock up feature? Does that matter at all in this case?
when i had the narrower C4 bell on with the C4 converter (2500 shahl) it at least kicked into all the gears just stalled out. Like i said, it sounds like something broke internally from that converter because all i hear is something clanging around inside of it when i picked it up off the ground. My C5 converter dont make any clanging noises at all, same with another converter i have layin around.
Tempted to get a C4 bell only the 6 bolt one (mine is a 5 bolt for a 289) and a new C4 converter
mmm im thinking a 289 is the same bolt pattern as a 302
You're really confusing things now. Is your 289 a 5 bolt block ? Or a 6 bolt? What year C-4 is it? Is it the early 5 bolt bell C-4 ? Or the in between the 5 bolt and 70's C-4 ? (this would be a 24 spline input shaft C-4) In about 69 or 70, Ford revised the C-4's with a 26 spline input shaft.
Featured Ranger Based Vehicle
