BlueLighting1999
Yep, your new intake probably has a cone filter attached to a round pipe? This air filter probably has little or no shroud to block out engine compartment heat so now you're pulling in warm air instead of cool air. The only aftermarket intake I would recommend is the Volant as this has a full engine compartment shroud.
I had a 3.0L Ranger that I installed JBA headers, BBK 56mm throttle body, ported/polished intake, Volant intake, 1.7:1 crane roller rockers, underdrive pullies, electric fan, hotter coil, and advanced the ignition 4 degrees. It was a single cab and had 3.73:1 gears. One of my friends had a same year OHV 4.0L with 3.55:1 gears and a muffler change and it would still walk my truck. So, that tells me the 3.0L was still at or under 160 hp. Because of this parts list (and the body of the truck had a lot of work) I was able to make a good buck when I sold it.
And if you're still reading about my experience. I swapped in a 93 cobra mustang 5.0L with a carb. That was fun. Then I pulled it for what I'm building now (400hp mechanical cam'd 306") And my future plan is to build a 408w stroker. You see the pattern?
Most all of the parts to build more power out of the 3.0L are going to raise the powerband. In a 4x4, the 3.0L's main complaint is the lack of low end torque. You'll have LESS torque down low with most of these add-ons. You have multiple real world choices
1. Leave the engine
2. Force some air into the engine (this will give you a desirable powerband)
3. Swap for a larger engine
But, its your vehicle so this is the last advice I throw out there.
Oh crap i never thoght of the frist part man... Is there anyway i could make a shroud at home??? Because when i get in the high RPMs i would be sucking up hot air and not cool air man......
