3" suspension lift
mounties83
Ligonier
I have a 1993 Ford Ranger Splash with a 3" suspension lift. I want to replace the shocks cause they a worn out. I was looking at Skyjacker's but im not too sure on what ones to get. H7054 for front. H7058 or H7060 for the back. are these right? i didnt do the lift so i have no clue. But right now they are rancho shocks but i cant see any writing on them cause they are all rusted. Any help would be appreciated.
A way to tell what shocks you need is to jack up the truck so the suspension hangs, then measure the distance between your mounts. Find a shock that doesn't limit the suspension's travel by more than an inch or so.
On a 3" lift, you'd normally look for shocks that have an extended length between 17-18" (front) and 26-28" (rear). Or maybe just match something up with your old shocks.
i have no idea and you think back H7060, and front H7052's would be good
