Mountain_Goat
- Feb 12, 2009
I am doing a SAS on a 95 2wd supercab Ranger. I am getting a a complete Wrangler dana 30 from a junkyard with all brakes, leaf springs, steering linkage. I hope to make it all fit as cheaply as possible. I am only going to run 31's. Will I need a high steer kit?
This seems pretty straight forward so I am afraid that I'm forgettign something. My plan is to torch everything off the front and trim my engine crossmember. Then I will weld up spring and shock mounts. THe stearing is where I am confused. Should I get the Wrangler steering box? Pump?
Also, before you tell me that the dana 30 is to weak, I dont plan on doing anything more than getting into some mild mud a few times a year. This is my DD.
