zukirider21
alright so im trying to button up my lift kit this weekend, and im almost done, but ive run into a snag.
the steering shaft extension piece seems a bit too short. (89 ranger 2wd ext cab 2.9 a4ld) it fits inside the firewall side of the shaft just fine, but its not working out so good for the other side (off by about 3/8 - 1/2"). if i try to put the extension in the u joint side first, its pretty tight. if i hammer it in to that, will it be ok to use some "negotiation" (i.e. yanking the crap out of the shafts) for getting it inside of the other shaft?
and isnt the steering shaft supposed to be slightly telescopic in stock form? cause mine sure isnt...
