3" body lift questions
conjohncept
Rensselear, NY
anyone know where i can get a 3" body lift cheaper than $200 and I have a 5spd transmission and a lever to put it in 4x4, am i going to get a extender fort these levers?
Summitracing has one for around $120ish. Idk how much the extender's gunna run ya, but it should be fairly simple/inexpensive.
look in TRS fab and offroad, there's a shift extension there for $38 and some change.
Yes, My PA body lift was bought from Jcwhitney for about 120 dollars. the shift exstension bought from here for about 40 dollars, unsure about the 4 wheel drive, if they make a exstension for that.
the body lifts for pre-97 and 98 plus are listed separately, usually with the former being around $120 and the latter running $200.
I extended my 4x4 lever with a peice of shaft from a tractor starter armature (same exact diameter) and a piece of pipe welded together. I drilled and tapped a hole in the pipe so when I slid it over the stock lever I would have a setscrew to hold it in. The stock boot covers everything up and with a little black spraypaint it looks 110% stock.
i got you
well when i got my 88 ranger it all ready had a 3" body lift. i rellized that the t case shifter was low and came close to hiting the stick when shifting 1st ,2nd.so i hade a extra dodge tcase lever (crome:thefinger:) laying around its about 8 or 9 inches long,cut the old shifter welded the dodge one to it. lookes good and works way beeter than the ford one lol. i like it allot locks like it was ment to be:headbang:
