3.8 SC ranger
steven
Just wanted to post couple of pics of my project still have some little stuff to finish up. Drove it a few times around yard still have to put front drive shaft in and lockouts on it. Makes pretty good power 13 psi boost I think with a little more run time and tweaking should make little more. View attachment 8488
Truck looks good!! cant wait to see more!
So I got my front drive shaft built last night and got it in Im a little worried its going to be to much of an angle when I flex it was 13 degrees with truck setting on flat ground anybody have or had this problem. Drive shaft is about 24'' long.
what trans/t case are you using?
Using an aod with factory ford adapter with 205 factory clocked. Is 13 degrees to much or questionable.
its livable though with higher maintenance.
