3.73 shims with 4.10 gears?
Ranger Sport Honduras
Zoom Zoom
OTOTM Winner
Solid Axle Swap
Honduras
Fortune Favors the Brave
im about to get a 4.10 ring and pinion for my 7.5"
1) do the 3.73 shims work with the 4.10 gears or ill need an install kit?
2) if so, i could get the minimum install kit or i need a master kit?
3) the gears are Ford, so does it matters that the shims are non Ford? like genuine gears for example.
thanks!
There is no carrier break on the 7.5 axle. So you can use the carrier from the 3.73 for the 4.10 gears. If you are asking about reusing shims, don't. Measure then and replace them with new shims. Brand does not matter, they are steel spacing devices. Just make sure you use new ones.
There are thicker shims placed on the outside of the shim stack on some carriers. Most of the time they are cast steel and after-market forged steel ones. Forged being better.
There are also solid steel spacers available to set the preload with instead of a crush sleeve. I don't use crush sleeves anymore on Ford axles if I have a choice.
ok the carrier , i had that clear, but thanks for the confirmation.
so ill need the install kit?
http://www.trsfabandoffroad.com/products/ford_75-88_gears.htm
the minumum kit has the following:
Ford 7.5 Installation Kit
(Pinion Nut, Pinion Seal, Pinion Shims, Carrier Shims, Crush Sleeve, Ring Gear Bolts, Gasket & Marking Compound)
can i use the 3.73 bearings for pinion nad carrier or do i need the master kit with all those?
Ford 7.5 Master Install Kit
(Pinion Bearings, Carrier Bearings, Pinion Nut, Pinion Seal, Pinion Shims, Carrier Shims, Crush Sleeve, Ring Gear Bolts, Gasket & Marking Compound)
Ok, we have a lot to discuss here.
1. Do you plan on installing these gears yourself? If so and you have never done them...it is not a simple bolt in affair, and is quite complicated.
2. If youre serious about it, youll need a wide variety of special tools to do the install, and I suggest you get reading now. If you cant answer the questions you asked in your first post by yourself, then you arent even close to being able to install them.
3. Read this: http://www.pirate4x4.com/tech/billavista/Gear_Setup/
Once youve read that thoroughly, re-evaluate whether or not you think youre going to be able to install them.
4. If you are actually going to go through the process of setting up a new set of gears, then get a YUKON master install kit, and replace all the bearings in the differential. Dont try and half ass it.
The kit will come with new carrier bearings, as well as inner and outer pinion bearings. It comes with 2 crush sleeves, because more than likely you WILL ruin the first one trying to set the preload on the pinion bearings.
5. If it is indeed a used gear set, than focus on trying to get a good pattern on the coast side of the gears. The coast side usually isnt worn as much, and is able to give you a much more readable pattern.
If you have questions feel free to ask, but realize that this is not a trivial task, and setting them up wrong can result in catastrophic failure.
Cheers,
Nate
im taking it to someone that has done this work.
but ill order the install kit since thats not available here. i was thiking about the genuine gears master kit, but if u recommend yukon, ill try to get that one.
but after reading the article u provided, well im more scared lol
regearing it will be cheapier than gettin a complete axle, but again swaping axles is by far more easy.
i will analyze the situation and talk to my cousin(he will do the job) and see what he says.
thanks for the help.
Any time I replace gearsets , I always reuse the shims. 9 time out of 10 the pattern is right on. That is from 20 years of experience.
I use the original shims as a starting point, gives you an idea anyways. When I did my 4 56s in my 8.8 however, with the stock shims, I couldnt even get the carrier in the housing, ring gear was too thick. But yeah, it will give you a starting point.
When I did both my 8.8's (28 spline and then my 31 spline) I got a good pattern with the stock shims. I reused the same gears between the 2 but went from stock open carrier to a Detroit with the 31 spline. I always start with the shims that were in the diff as well...and it is usually very damn close if not good to go. There is no problem reusing old shims.
i couldnt talk to my cousin today.
as for using the existen shims, thats clear now, we will use the stock ones to get a reference point. Then we will use the new ones until we get the perfect pattern.
so could i go cheap and get a minimun kit or do i need a master kit with bearings and all?
and its genuine gears reliable? i know Yukon is the best, but its kinda expensive.
ok ive made my mind, ill save a bit more money and just dig out for an axle with 4.10 gears in it. hopefully i could get a limited slip too.
im not confident enough to tear apart the main part that moves my truck.
thanks for all the input
Hey good call, I think you made the right decision. It will be much simpler and quicker for you to just swap out the whole axle. And in the end, I think it will cost you less. If you have any questions though, or if you DO decide to go through with it, done be scared to as questions, or shoot me a pm.
cheers.
For a little encouragement.
I swapped out both my front and rear with just a hour or so of research. It the job took me 3 hours for the rear and another couple for the front. Mostly due to making sure I was getting it right.
Minus the couple hours I spent rebuilding the L/S carrier prior to the entire affair.
In both cases I ended up reusing the original shims. I had bought new ones. But after fairly careful measuring and positioning. The original shims had no wear and they seated better then the new ones.
cheers.
yeah. like i said, a limited slip would be nice to find too.
even my stepdad(who is a dentist too lol) told me its better for me to swap the whole axle. less things to go wrong that way.
Thanks for all the info u gave me. and yeah whenever i need help ill keep u in mind :icon_thumby:
Cheers,
Nate
Actually installing gears is quite simple...
The problem is there is very little margin for error on proper installation and if you do the slightest thing wrong the parts WILL self-destruct, because of how severly they are loaded.
But you'd be suprised how sloppily many of the production rears are actually set up by some lazy ass UAW worker that simply doesn't give a damn.
there is an exhaustive complicated setup proceedure that if followed will give consistant results.
the rub is that for follow that proceedure you need $2500 worth of special tools that nobody except a few dealers bother to buy.
(I personally own those tools but I'm weird...)
For general purposes if you get a replacement gear from FORD the g3ear will be paint marked on the shank with a Big " 0 ". this indicated that no correction is required to the shimming.
IF the pinion gear you remove from the axle is also marked w9ith a zero you can reinstall the original shim, but what I;d recommend you do is measure the original shim and install a new shim the next size thicker...
Why? because in service the original shim got itself crushed down
by .001-.0015", so it's now thinner than when the factory technician
installed it.
then the pinion nut must be tightened carefully to achieve the proper pinion bearing preload (with new bearings this is ~20in/lb, and 20in/lb needs to be measured with a torque wrench, and ththis is the torque that it takes not to get the pinion moving but the torque needed to keep it rotating smoothly
(this is a ticklish measurement to make, but if it's eather too tight or too lose the bearings self-destruct)
Backlash must be CHECKED but on my personal truck after setting aside the original final assembly shims and following the procedure EXACTLY I've wound up reinstalling the original side shims back in the housing through several carrier and gear swaps... (red the proceedure below and then come back this paragraph to understand how perverse this is)
the proceedure you are supposed to follow is by installing a shim of known thickness (a 0.265" thick shim) on the tooth side of the carrier then fit the thickest shim that will fit on the "Back side" of the ring gear with a "sword-in-the-stone" fit.
Measure the backlash (ideal ring gear backlash is 0.013",
but anything between 0.008 and 0.018 is "acceptable"
Now after you have swapped shims (actually cast iron select fit spacers)
to achieve the correct backlash you REMOVE both shims and replace each one with a shim that is 0.005-0.006" THICKER, this is to achieve proper carrier bearing preload
if you don't do this the carrier will literally slam side to side as you get on and off the gas and this can wreak havoc inside your rear ddoing anything up to physically breaking the axle housing!
And now review the paragraph above where I said on my own 8.8" axle
I'm using the original factory shims in their original locations....
and this is with three different gear sets and four different carriers my
axle is currently wearing the shims that were installed in Dearborn sometime late in 1995.
So just how critical is it all? very, but the precision of the factory parts usually obviates most of the effort in making SURE it is right.
And even though on my own all the measureing and checking leaves me exactly where I started, I'll still check it all again, next time, because there
are such diasterous consequences if something isn't exactly right.
I really don't want to have my axle fail on some desert washboard road 20miles from the nearest cellphone coverage and 40miles from the nearest road with pavement....
OR fail somewhere in the middle of any of the five states that seperate my place in Pennsylvania from my brother's in Wyoming...
So even though I know EXACTLY what I'm doing and know that in all likelyhood that I could take it all apart and put it back together with parts picked randomly off the floor of my shop and that it'd likely work for 10k-15k miles without any serious issues I still check everything because "likely" isn't nearly good enough when you are 1000 miles from home or family rescue.
Generally speaking I just don't feel that lucky...
If you do, go for it... but make sure you don't call me if it all goes wrong unless you want your free "I told ya so"
AD
installed it.
AD
well thanks alot of the explanation, i seem to understand it a bit more now.
but ill go the easy way. ill just get an axle with the gears i want already in it.
ive been asking for some general opinions and once they stop calling me truck crazy, they all say go for the easy way lol
so if i get an 8.8 axle, it will bolt the drive shaft of my truck with no problem, right?
