3.0 wont start
brandon15
ok ive broke a connection rod on my first motor, got sent a bad motor and swapped that out, now my third motor i dopped in im not gettin it to crank, it will turn over and try but it acts like the starter is bad but i took it to autozone and they checked it and said it was good, is there anything they could of missed to make it still be the starter? or is there anything else anyone can think of for me to try? thank you
Starter cable maybe?
Weak battery?
Do you have spark? Do you have gas?
Make sure the crankshaft position sensor is connected ok.....
starter wires are fine checked hole wiring on motor i got gas i smell a lot of raw gas burning now and it almost wants to crank it just wont start up its turnin over and clickin the hole time if you understand that...i got smoke comin from the where the egr connects to the exhaust manifold but i they had oil all of the motor i think its just burning some of that off. im thinkin now either a bad plug but i cant find nothin
where is the crank sensor so i can check for a cut wire or somethin?
k its not the crank sensor now im thinkin and hopin maybe just the plugs fouled out with all the fuel gettin in them tryin to crank it ill swap plugs in the morning and go from there i guess
