- Oct 31, 2018
- Dirtman's Basement
- My credo
- Give 'yer balls a tug. Fight me.
So, any chance you can shoot a few pics of the ports? Curious to see how much potential is there
It looks so small and helpless this way.
Insides look ok to me.
I do like those better and have used them many times in the past. But that would require drilling a much larger hole that I'm afraid would weaken the tab.This style thread repair insert works better than helicoils for this situation.
If you have to do that again, grind the broken bolt off flat. Make a drill guide/bushing out of a piece of metal using two of the good holes to position the guide. Use a small diameter bit to make a hole in the guide that is right over the nominal center of the broken bolt - then you can make a pilot hole right down the center.
You can still use that approach to drill out a larger hole for a helicoil, but you'll have to use a larger guide hole of course. And you'll probably want to make the guide out of steel so it's strong enough to keep the bit from walking.
You can be pretty far off on an exhaust bolt, those holes are usually pretty sloppy!That's a good technigue, thank you. I actually had a set of easy-outs from Blue Point that included drill guides that would have slipped over the remaining stud I had sticking out IF they were metric. But I only had the SAE set and they didn't fit close enough. I still tried the easy-outs and broke 2 of them.
I also tried bolting the exhaust manifold on to use it as a guide like what you are suggesting. But there is too much clearance in those holes. In fact, it was such a sloppy fit I didn't feel comfortable that I could center it over the hole in question. So I eye-balled it as close as I could, center- punched a mark, and started my hole with a center drill like you would use in a lathe. I figured the center drill would be straight and also stiff enough to resist walking.
That damaged hole will be close enough to guide the drill for larger threads or helicoil threads. I'll make the final decision and repair it later when I have headers in hand so I know how much clearance I have for a fastener and wrench.
FE upper exhaust manifold bolts were the same, they went all the way through the head and often had to be drilled out.
The cylinder walls look like they would hone out and be fine, the bearing journals look good,too. Obviously they'll need to be checked for clearances but this may be a straight forward overhaul. I assume you're planning on a different cam, if not you should because of the wear on the syncro gear- the drive gear on the cam probably looks beat,too. When picking a performance cam for the street the rule of thumb is buy the next one smaller than you think you need. 3.0's are a nice little engine, I'll be interested to see how much you can improve the torque.
#FiestaSometimes engines is never goes vroom...
