- Aug 11, 2007
- Age
- 38
first ill start by saying i didnt get off with this swap on the right foot. i didnt get a complete doner truck.
ok so the specs
93 ranger 3.0 with a4ld
was told the motor and what part of the harness i got are from a
94 explorer 4.0 a4ld
bellhousing from
19?? broncoII 2.9 a4ld
bellhousing bolted right on to my trans. im using the 3.0 torque converter and the 4.0 flexplate. the TC bolts line up with the holes in the felxplate.
problems
1. the motor wont turn over after tightening the bellhousing bolts. i set the motor in and lined up the torque converter bolts and tightened down 2 of the nuts then tighted down the bellhousing bolts. and then tryed to turn the motor over to get the other two TC bolts but couldnt. loosed the bellhousing bolts and it turns over. took off the TC nuts then bolted the motor to the trans but still got tight.
should the 3.0 TC work with 4.0? how much free play should there be in the TC to flexplate when engine bolted to trans?
2. Wiring. im sure i can figure this out and there is alot ALOT of info on the web about it. just wanted to say that i should have gotten all the wiring from the same truck.
ok so the specs
bellhousing from
problems
