cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
Right now I have a 1999 3.0 with a 5 spd manual, and a 7.5 rear end with 3.73s, 4x4. Spun rod bearing and I'm done with this stupid motor. I found a 98 4.0 ohv with 153k that comes with everything for $300 (the guy drops 5.0s in these rangers he said so it seems legit). I found a 5 speed manual for a 4.0 ohv from 98 for $450. My questions are:
1) can ford reprogram my 3.0s computer to the 4.0s so I don't have to deal with pats?
2)if they can't, I found on rockauto it's $115 for the ecu, what do I have to do when dealing with the pats?
3) do I have to change the wiring harness?
4) how long will my 7.5 hold up?
5) what other issues will I run into? Will the tcase bolt up to the 4.0s tranny? Will the driveshaft need to be changed?
6) is the battery group the same? My interstate battery is good so I don't wanna deal with changing that!
7) if I need to change the wiring harness, will a 4.0 auto wiring harness plug into the 5 speeds ecu? The autos are a dime a dozen compared to the 5 speed.
8) what about fuel system? Will the fuel line click into the 4.0s fuel rail? Fuel pressure the same?
9) any other issues?
Thank you very much!!
Chris
Chris
