- Jan 24, 2018
- Tallahassee Florida
- Total Lift
- Stock 2"
- Tire Size
- Stock
- My credo
- Doing things wrong, until I get it right.
The Google says 250-280 hp, depending on the year of the LS v8.
Those numbers are from the first released 4.8/5.3 gen III'S. Still good hp numbers. Ls gives you plenty of options to choose from. The 6.0, 5.3, and 4.8 all share the same block. 4.8 is higher compression ratio because it has flat top piston which makes it great for boost applications. The 6.0 has a larger bore than the others (4.00vs 3.78). In it's early years the lq4 produces around 340hp/360tq No matter which one you choose they all fit in the exact same mounts and everything is the exact same bolt pattern. Either one you go with a good cam and springs is all you would need to push 400hp/tq on the 6.0 n/a.The Google says 250-280 hp, depending on the year of the LS v8.
Will the Duratec mount to my M5 trans.From what I know, there are 3 - 3.0s:
1. 3.0 Vulcan stock Range
3.0 Duratec out of Escape would make interesting swap but:
The reason I was asking about Wheel bases is, If I change transmissions to one that may be longer than mine, would the ExpoSport driveshaft work? I see there is about a 10" difference, would that be roughly a 10" shorter driveshaft?
My bad. You still have some info on the chevy ls either way.No. The numbers I was looking at are for the 3.9 litre Jaguar v8 in the Lincoln LSE not a Chevy LS.
This is trueMy bad. You still have some info on the chevy ls either way.
