55trucker
- Aug 1, 2016
- Oshawa, Ontario
- 3.0 V6
- Automatic
- Total Lift
- Total Drop
- mild
If you've got this......
under your '92 (which is what is under my '98) you won't find that for $50, if you suspect that the cats are clogged get under the truck and give both cats a rap with a ball peen hammer, if the sound is a dull thud they are more than likely still good but if the sound rings or has an echo to or you can actually hear loose pieces inside moving about then the substrate has collapsed and usually collects at the tail end and being the way they are manufactured if one has gone then you're replacing both of them. Cats don't generally fail on their own, something upstream in the fuel system has gone wrong and over a good period of time will take them out.
